Activity Forums Adobe After Effects Most Efficient QuickTime w/ Alpha
  • Most Efficient QuickTime w/ Alpha
    Posted by Michael George on May 25, 2015 at 6:39 pm
    I’m creating a running clock animation for a sports webcast that uses Telestream’s Wirecast. Because the composition is very long (the length of the game), I’d like to know the best route to deliver a QuickTime with alpha that minimizes file size.
    Matthew Woods replied 11 years, 3 months ago 3 Members · 2 Replies
  • Walter Soyka
    May 25, 2015 at 6:46 pm
    There’s really no such thing as a light-weight production codec that supports alpha.
    For a clock, I’d use QuickTime Animation codec, but since it only update every second, I’d make the comp and output movie run at 1fps; that’ll instantly cut the file size by a factor of 30.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Matthew Woods
    May 26, 2015 at 2:55 pm
    1 fps is a great idea. Another thing to consider is having separate rgb and alpha movies, and luma matting/track matting the color movie with the alpha. Then you can use whatever codec you want for your rgb. Depending on your animation, for something like a clock, you might even be able to use a still image for your alpha channel.
    Need a quick break from motion graphics?
    Try my game Constellation at:
    https://www.paperdragongames.com
