Activity Forums Maxon Cinema 4D MoSpline Segments + random Clones
  • MoSpline Segments + random Clones
    Posted by Crasse Deux on October 29, 2015 at 3:46 pm
    Hi there !
    I got a Mospline with 6 segments and I wrap on them different clones from a single cloner (containing 8 different objects) using a Spline Wrapper to bend clones along the spline.
    The SplineWrapper part works But my problem is that clones are dispatched in the same order on each segments of the MoSpline and I want them to be in different order on each segments.
    Is there any way to do that (without turning the Mospline into a regular spline) ?
    Crasse Deux replied 10 years, 10 months ago 2 Members · 2 Replies
  • Nick Smith
    October 29, 2015 at 3:54 pm
    Off the top of my head, have you changed the cloner setting from Iterate to random?
    Nick Smith
    “So long, and thanks for all the fish.”
    http://www.anarkyanimations.co.uk
  • Crasse Deux
    October 29, 2015 at 4:10 pm
    Hi !
    Yes I did that, but didn’t get any results, clones order changed a bit between Iterate and Random, but still, they are ordered the same way on each segment.
    However I located a bit the problem.
    It come from the SplineWrapper.
    If I use the cloner on object mode and then use the MoSpline as the object, clones a randomly dispatched on the segments, but in my case that won’t do the job because i need the clones to be wrapped on the spline. (the object mode keep the clones “rigid” and they don’t bend according to the spline).
    Another fact, even If I “rasterize” the Mospline (pressing C) to turn it into a regular spline, Using the spline wrapper, clones still are ordered the same way on each part of the spline that were segments. really weird…
