Activity › Forums › Adobe After Effects › Morphing on Shake with ReFlex
  • Morphing on Shake with ReFlex
    Posted by Nuno Pires on March 20, 2008 at 12:10 pm
    Hello,
    I am trying to make a morphing between two stills with the plugin Reflex Morph on Shake, but I can’t understand how to use reflex tools to mark points and shapes in each image (the “from image” and “to image”). Is there a tutorial explaining how to do it?
    Actually, I don’t mean to make a real morphing, but transform a white face to another one. Is there a better software to do it?
    Thank you.
    Pierre Jasmin replied 18 years, 6 months ago 2 Members · 2 Replies
  • Pierre Jasmin
    March 20, 2008 at 7:46 pm
    Before I say more did you see the html doc that was part o install package?
    Also some sample project in the support section
    http://www.revisionfx.com/products/reflex/support/index.html#Shake%20(Apple)
    Note if it’s not obvious the second shape uses Shake rotospline offset button
    Pierre
  • Pierre Jasmin
    March 20, 2008 at 8:30 pm
    It’s actually called the “Edge” button (in the viewer notice when in RE:Flex how the rotosplines control show up). Sorry each app call this something else.
    If you move a rotospline and check Show/Hide and switch between From and To Sources in RE:Flex, you will see the from and to shape thing
    Once you have a few matching lines, you can then maybe use the AutoAlign button (depends on how far off the source and destination are, it’s usually to match two faces, or a face with a textures/shaded CG face…)
    Pierre
