Activity Forums Adobe After Effects morphing into particles
  • morphing into particles
    Posted by Abra Kadabra on October 10, 2007 at 12:54 pm
    I want to make a human being to turn into particles(using trapcode particular)
    and I guess the reshape effect won’t suit here.
    does anyone have any suggestion how I can do this(i have the human and the particles I just need the morphing issue solved)
    the human is masked,it wasn’t shot on a green screen
    thanks for the help
    Mike Clasby replied 18 years, 11 months ago 3 Members · 2 Replies
  • Kevin Camp
    October 10, 2007 at 4:28 pm
    here’s a tutorial that could be adapted to your project, called text that blows away like sand. you may even be able to adapt it to particular….
    but, to give you a some quick help in particular… set the emitter to layer or layer grid, then select the layer to be used (it needs to be a separate layer than the one the effect is applied to). choose thelayer rgb usage as rgb particle color. if using layer grid, click the ‘options’ at the top of the effect, on the right side of the options window will be grid emitter settings, these will affect the spacing or the particles as they are first emitted.
    that should get you to a point where the layer kind of bursts into particles. after that it is a matter adjusting amount of partcles and how they behave after birth…
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Mike Clasby
    October 10, 2007 at 4:40 pm
    Trapcode Particular
    Building Up Particles
    https://www.creativecow.net/articles/lee_james/particle_build_up/index.html
    Particle Illusion (30 day fully functional trial, methinks)
    Disintegrating People and Other Things
    https://www.creativecow.net/articles/deane_elvis/disintegratePeople/index.html
    You can also try a combo of CC Ball Action (Grid spacing 0, animate scatter) + Scatterize + CC Flo Motion.
