Activity Forums Adobe After Effects Morphing in AE – suggestions
  • Morphing in AE – suggestions
    Posted by Pablito on October 4, 2007 at 12:36 pm
    Hi…
    I am going to make a commercial that show the history of a logo so I have to morph/reshape each logo to another from the first version to the last one…
    My files are eps images so I have an aplha channel…
    Whats the best method/plugin to make the job in AE? Should I have to use masks for each logo or there is something I can use to morph/reshape from one logo to another using the alpha channel in each file?
    Thanks a lot
    p
    Joe Castiglioni replied 18 years, 11 months ago 3 Members · 2 Replies
  • David Chaudoir
    October 4, 2007 at 12:49 pm
    Re:Vision Twixtor does quite good morphs.
  • Joe Castiglioni
    October 4, 2007 at 8:18 pm
    Have you tried using Layer-Auto Trace to get a mask around the edges of each version of the logo, then use Reshape to morph from logo to logo? That would still use masks, but it’s a quick way to get a mask from the alpha. You might’ve already thought of that, but I figured I should suggest it since I found out about Auto Trace on this forum and used it for something similar. Just an idea. 🙂
    Taikwanjo
