Activity › Forums › Adobe After Effects › Morphing an “I” to an “S”
Posted by Mike Wheeler on April 10, 2007 at 7:50 pmHey..
I know this is simple, but I’m having some problems… I am trying to make a straight line morph into something that is similar into the shape of a sideways “S”… how do I go about doing this?
Any help is appreciated…
Mike Wheeler replied 19 years, 5 months ago 2 Members · 4 Replies -
John Jackowiak
April 10, 2007 at 8:18 pmcreate a mask on a solid layer, and click the shape choice under your mask settings to set keyframes. One in the shape of an “I” and then reshape it into an “S”. The apply “3D stroke” or “write-on” to get your stroke color and width. Hope that helps.
Mike Wheeler
April 11, 2007 at 11:59 amThanks for the reply, but when I do this it gives me really weird morphing results… it does start and finish in the shapes I want, but the morphing in between is really weird and not looking at all like I want it to… when it goes from the “I” shape to the “S” it turns into something that looks like a rubber band instead of remaining a solid bar…
Any ideas anyone?
Thanks again!
John Jackowiak
April 11, 2007 at 2:02 pmI think that may be from connecting your endpoints of your mask. That would give you that rubberband look during the morph. If you leave the mask open ended, it should reshape nicely. What effect are you trying to use?
Mike Wheeler
April 12, 2007 at 11:43 amI was using the effect that you mentioned, using the 3D stroke with the mask shape… I’ve tried leaving it open ended and still can’t get the results I am looking for…
Back to the drawing board!
Cheers..
