Activity › Forums › Adobe After Effects › Morph madness.
Morph madness.
Posted by Malcolm Desoto on October 25, 2007 at 8:25 pmOkay, I need to morph two guys together. The only tutorial I found was for V 5.5. Is this effect still done this way? Seems like there’s an easier way…
I’m using AE 7 Pro.
Malcolm Desoto replied 18 years, 11 months ago 4 Members · 11 Replies -
Nicholas Toth
October 25, 2007 at 8:27 pmCan’t you roto them and then use a cross disolve/clever transition along with a reshape effect? You might also want to check out RE-shape, word on the streets is that its pretty awesome.
https://www.revisionfx.com/products/reflex/
Malcolm Desoto
October 25, 2007 at 8:36 pmgaaaarrrrr…yes.
I have no money for third party plug-ins.
Steve Roberts
October 25, 2007 at 8:47 pmThe only morph-like changes in AE have been the Puppet Tool and Liquify. I tried morphing with the Puppet Tool and it was a real chore, taxing the system. I don’t think it was designed for that.
Liquify is much better, in my opinion. Give it a go.
Malcolm Desoto
October 25, 2007 at 10:09 pmYou ask if I have clean plates? They are all currently in the dish washer.
No clean plates for this project.
Malcolm Desoto
October 26, 2007 at 12:32 amThe camera was, indeed, locked down.
Build a clean plate? Would you try to auto trace them? I really don’t want to animate a mask by hand.
I’ve already got the morph pretty much finished up. It looks decent. I would like it to look a little better though.
I’m going to play with it a little longer and then post the results.
Malcolm Desoto
October 26, 2007 at 2:24 amOkay, so it’s supposed to span from “the olden days” to now.
The morph is still a bit rough
Suggestions are welcome. So far, this is just the Reshape effect and trancparancy values.
Jimmy Brunger
October 26, 2007 at 9:07 amYeah, I reckon you could still get a better result with reshape or liquify..try splitting the different obvious shapes/groups into diff layers and morph like for like pieces, rather than the whole thing as one.
You might be able to pick up Elastic Reality by Avid on Ebay cheap secondhand..they don’t make it anymore, but it was the forerunner to Re:Flex and is still very good. With this you can employ several groups of boundaries that will freeze certain areas, but pull others the way you want them to go and you can start different parts of the morph staggered, whilst keeping it all one ‘layer’ if you like.
*Production Studio Premium CS2 / *Combustion 3 / Mocha v1
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Roland DS-5 monitors / Sony BVM-20G1E / DVS SDI Clipstation / Wacom Intuos 3 A4 / 110GB boot/80GB media/600GB RAID-0
