Activity › Forums › Adobe After Effects › Morph logos
  • Blaise Douros
    April 30, 2021 at 7:56 pm
    Right now, you have two different paths for the “a” character. Basically, you only want After Effects to have one path present, but the
    keyframes that you set will make the paths change. Keyframe 1 is the
    original “a,” and keyframe 2 is the altered “a.”
    What you want to do is copy the path keyframe from your altered “a” into the path for the original “a,” so that it changes over time. Then you delete the extra one.
