Activity › Forums › Adobe After Effects › Morph heads
  • Morph heads
    Posted by Gonzo15 on September 4, 2007 at 5:02 am
    Help me please.
    My problem, I have a HDV image of an actor 1 (mid shot) he delivers a line, then what I want is his head to morph into another actors head (actor 2) but keep actor 1 body, then actor 2 delivers a line using the voice of actor 1 and then change back to the original image.
    The voice part is not an issue but the morphing head keeping the same body is.
    Any help would be great.
    I have AE 6.5, Motion 2 and shake if that helps
    David Del replied 19 years ago 4 Members · 4 Replies
  • Steve Roberts
    September 4, 2007 at 12:07 pm
    Did you search the COW for “morph”? Methods have been posted. Try the archives.
    My 2 cents: I like Re:flex for morphing, but you have to buy it. Regarding keeping the body, you can mask out the head or mask out the body — that’s the easy part.
    For alternatives, search the COW, as I wrote.
  • Roland R. kahlenberg
    September 4, 2007 at 12:17 pm
    Here’s a COW Tutorial by Chris Zwar on morphing with AE. It’s quite good – https://library.creativecow.net/articles/zwar_chris/morph.php
    ReVisionFX’s Flex should do the trick with less pain.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Gonzo15
    September 4, 2007 at 12:46 pm
    Great thank you, I got the Cow tutorial.
    Thanks again.
  • David Del
    September 9, 2007 at 4:40 pm
    Is RE:flex the only plugin that is good for morphing?
