Activity › Forums › Maxon Cinema 4D › More xRef woes
  • More xRef woes
    Posted by David Cabestany on August 5, 2016 at 3:15 pm
    I’m trying to add a model inside another scene, this is the way the model looks in the original file:
    But this is how it looks when the xref is placed in the larger scene:
    This happens when I check “Generator” on, I’d leave it off, but then I can’t move the contents of the xRef to a different layer. Since my scene is very complex, I’m hiding everything I don’t have to use until I’m ready to render.
    Any ideas will be greatly appreciated.
    D.
    David Cabestany replied 10 years, 1 month ago 2 Members · 2 Replies
  • Brian Jones
    August 6, 2016 at 3:47 pm
    did you animate the character in the master file then turn on Generator?
  • David Cabestany
    August 8, 2016 at 3:06 pm
    Hey Brian,
    No, nothing is animated. It’s just an illustration. All other xRefs are behaving correctly, only this one is weird.
    Best,
    D.
