Activity Forums Avid Media Composer More xpresspro trouble
  • More xpresspro trouble
    Posted by Editing Jane on July 27, 2007 at 5:31 pm
    Hi all,
    I was so excited with my new system and now I’m going through “growing Pains”!
    When I shut down I get this message everytime:
    Microsoft Visual CTL.runtime library
    Runtime Error!
    Program D:\AvidXpressPro\Avidxpresspro.exe
    R6025
    -pure virtual function call
    Anyone see this before??
    Avid is installed on the D drive of a new Dell XPS with plenty of drive space.
    -EJ
    Bill Clark replied 18 years, 9 months ago 3 Members · 4 Replies
  • Erik Pontius
    July 27, 2007 at 8:42 pm
    Haven’t see the error before.
    Microsoft has this enlightenment:
    “Calling a pure virtual function is a programming error, so you need to find the call to the pure virtual function and rewrite the code so it is not called.”
    Maybe time to re-install. Any reason why you Avid installed on you D:\ drive? Usual practice is to install the Avid app on the C:\ and use a second dedicated drive for capturing media.
    Erik
  • Editing Jane
    July 28, 2007 at 12:01 am
    Well, my C drive is much bigger, typical I suppose, re-installing is a good idea….this time on C…
  • Erik Pontius
    July 28, 2007 at 4:04 pm
    Usually, you do not want to capture to a “system” drive, the drive that contains your operating system files, since the OS will be reading/writing to the drive as part of it’s normal operation…this can slow down the performance of the drive and you can risk having problems with capturing (dropped frames, overruns, etc…).
    So if your D: is too small to capture video to, you may consider upgrading the drive to a larger drive or look into external storage (sata, firewire, etc…).
    Erik
  • Bill Clark
    November 27, 2007 at 9:41 am
    I’ve had this problem too when exiting Avid Express Pro. I didn’t get it on the last version only when I upgraded to 5.7. I’ve reinstalled twice and styill have the problem. Running on AMD Opterons 3 gig ram 3 TB drives etc – so memory / performance isn’t a problem. Any more ideas?
