Activity Forums Adobe After Effects More VS faster RAM
  • More VS faster RAM
    Posted by Lucas Schwartz on November 7, 2019 at 12:03 pm
    Hi guys,
    I am putting together a new PC build for graphics design. I was wondering which one should I opt for:
    Corsair Vengeance LPX 128 GB (4 x 32 GB) DDR4-2400 Memory
    CAS Latency: 16
    Timing: 16-16-16-39
    VS
    Corsair Vengeance LPX 64 GB (4 x 16 GB) DDR4-3200 Memory
    CAS Latency: 16
    Timing: 16-18-18-36
    The software I mainly use is Adobe after effects and cinema 4D.
    So would cinema 4D (and after effects) benefit from 128GB RAM running at 2400MHZ as opposed to 64 GB of RAM running at 3200MHZ?
    Also how would rendering performance and live view speed be affected by the difference caused in between the two different RAM modules please?
    Thank you for your answer.
    Kind regards,
    Lucas Schwartz
    Lucas Schwartz replied 6 years, 10 months ago 2 Members · 2 Replies
  • Tomas Bumbulevičius
    November 7, 2019 at 8:20 pm
    Hey Lucas, here is a part of a conclusion from Puget:
    There are some applications (Photoshop and NeatBench from what we tested) that can to potentially get up to ~13% higher performance with DDR4-3600 RAM. Just keep in mind that this performance is definitely not “free” – just like CPU overclocking, it is possible that it may cause more problems than the extra performance will solve and may require a bit of tinkering in the BIOS to get it stable over the life of your system.
    If you ask me – the cost gains and troubles from 64gb is not worth it over the quantity of 128gb. Maybe, just maybe, you could look for 2666 if thats applicable.
    Take a look at the graphs and conclusion: https://www.pugetsystems.com/labs/articles/Does-RAM-speed-affect-video-editing-performance-1528/
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Lucas Schwartz
    November 7, 2019 at 9:16 pm
    Hello Tomas,
    Thank you for your response.
    Your answer fully corresponds with the answer I have received from Pudget systems.
    I have emailed them today and I will copy and paste the reply I have received from Pudget for those who interested.
    Hi Lucas,
    Always, always, always go for more RAM over higher speed. The difference in speed will not be perceptible, period.
    It would be like you asking a question and getting your answer in a billionth of a second vs 1.25 billionths of a second. You just wouldn’t even be able to tell. Maybe if doing large amounts of RAM intensive scientific calculations it would make a difference, but even then, its minimal at best.
    After Effects in particular likes large amounts of RAM. 64 would probably be fine for either program, but if it’s about speed vs amount go with amount.
    It is important to match the RAM speed to the max supported by the CPU. Going over won’t benefit you and can cause instability. What CPU are you planning on using?
    The main factor for both programs is the CPU – After Effects is predominantly single threaded and likes CPU speed, and so does the design and animation side of C4D.
    Rendering, however is more dependant on high core counts. How much rendering do you plan to do?
    Live view is about RAM, that’s where the previews are stored, and more is better.
    I hope that helps. Let me know if I can answer any other questions.
    Jared Lewis
    Puget Systems
    jared@pugetsystems.com
    (425) 458-0273 Ext.1
    Schedule a meeting with me – https://meetings.hubspot.com/jared126
