Activity Forums Adobe Premiere Pro More Track Matte Effect Problems
  • More Track Matte Effect Problems
    Posted by Alex Kerezy on January 24, 2014 at 2:53 am
    So….since the track matte effects gets confused if the layers that is to be masked is being zoomed, or moving -or- if the layer that shines through is being zoomed or moving……. I moved/zoomed those layers and exported them as a video. Now premiere doesn’t know anything better, it’s just a video clip playing……………however
    If I set a layer to have a track matte effect, but there’s photo or video in the layer above – WHY, tell me WHY would it still mask it.
    Is there a way to turn track matte on/off with key frames? I can see that you can change the composite or reverse – but I want it on/off.
    WHY would someone design an effect with such limited use. This is SO frustrating. The world is not STILL, and our minds aren’t limited to the way you think we think.
    Churned in Charlotte!!
    Alex Kerezy replied 12 years, 7 months ago 4 Members · 4 Replies
  • Paul Neumann
    January 24, 2014 at 4:19 am
    Cut your fill layer where your mask ends. Remove the effect from the remaining clip length.
  • Ann Bens
    January 24, 2014 at 6:46 pm
    If the layer is to be moved or scaled nest them first and tweak the parameters in the nest.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Steven L. gotz
    January 25, 2014 at 7:59 am
    You can solve the movement issue the way Ann suggests, or you could use the Transform effect in the Distort bin. It gets processed differently than the Motion effect.
    If you want to eliminate a track matter for part of the time, just cut the video where you want to stop and start again, and then delete the effect on the portion that is cut out.
    Steven
    https://www.stevengotz.com
  • Alex Kerezy
    January 25, 2014 at 12:59 pm
    Thanks for the suggestion…………a better idea would be for the software engineers to allow on/off key frames of any/all effects as a whole.
