Activity Forums VEGAS Pro More than 300% velocity increase. Is this possible?
  • More than 300% velocity increase. Is this possible?
    Posted by Frank Manno on July 20, 2005 at 2:32 am
    I’m trying to create that ulstra fast speed up effect.
    I’ve added a velocity envelope to my video track and ramped it up to the
    max which is 300%.
    300% is not fast enough. I seem to need more like 3000% for this particular
    shot.
    I don’t really want to render out a section at 300% then bring it back on the timeline and
    add another 300% and so on.. What would be the easiest way to acheive my desired result?
    -Frankie
    Edward Troxel replied 21 years, 2 months ago 6 Members · 6 Replies
  • Peter Wright
    July 20, 2005 at 2:51 am
    The most you can get in one hit is 1200%. This is by maxing the Velocity envelope and Ctrl Dragging the Right edge to the left, which has a max of 400%. The two combined make 12x.
    Rendering then repeating is the way to go beyond this. (12 x 12 x 2 = 288 x)
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Timothy Duncan
    July 20, 2005 at 3:33 am
    Don’t forget that you can nest a .veg and not have to render but once. This way you can get 1200% x 1200%.
    td
  • Peter Wright
    July 20, 2005 at 3:39 am
    Good one Tim. Hadn’t thought of using nesting for that!
    Peter Wright
    Perth, Western Oz
  • Blue.eagle
    July 20, 2005 at 8:39 am
    another way is using scripts:
    the first one that cut every x frames
    the second one that get one frame for each event
    in this way you do not have to render
  • Lance Herring
    July 20, 2005 at 7:11 pm
    what script would that be? i see a use for this for condensing down and using a clip from a camera set for timelapse. we have a vx2000 here and have done a bit of timelapse, but it records a minimum of 1/2 second each interval. if i could chop just a single frame out of a long clip, every 1/2 second, it’d be perfect for the timelapse. i’ve done the trimming manually and it’s a pain of course for a long clip. would love to have a script for it!
  • Edward Troxel
    July 20, 2005 at 7:18 pm
    Look at “Time Bandit” in both the Veggie Toolkit and Excalibur 4. Excalibur 4.5 also has the Strobe Light tool which could work in a similar fashion.
    Edward Troxel
    JETDV Scripts
