Activity Forums Adobe After Effects More than 2gb in AE
  • More than 2gb in AE
    Posted by Twiggles on June 13, 2006 at 1:52 pm
    Hi there…
    I’ve just upgraded my system to a althlon 64 X2 with 4 gb of ram. How do I
    get after effects to recognise and use more than the default 2gb?. I read the
    help file but does’nt seem to be helpful at all. I’m running
    on windows xp sp2. I’m thinking if it’s worth upgrading to xp64 to fully utilize
    the pc but I heard that there are driver issues. Any ideas?
    Andrew
    Twiggles replied 20 years, 2 months ago 2 Members · 2 Replies
  • Colin Braley
    June 13, 2006 at 2:35 pm
    If you want AE to use more than 2GB of RAM search the archives (or google) for “3GB Switch.” It’s a line you add to you boot.ini file to get certain applications to recognize 3GB of RAM under Windows XP Pro. I would recoomend researching it some more before you use it. If you don’t want to do this, you can use Windows XP 64 bit editiion; I’ve heard AE works well and recognizes 4GB using this OS but I have never used it. For more info on RAM related stuff search the archives for posts by “Steve Forde” (President of Gridiron software, creators of Nucleo). Steve has posted many very informative posts regarding RAM in AE. One of the best can be found here:
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=867951
    ~Colin
  • Twiggles
    June 13, 2006 at 2:41 pm
    Hey Colin…
    Thanks for the tip. Will definitely check it out
    Regards,
    Andrew
