Activity Forums Adobe Premiere Pro more than 10 min capture?
  • more than 10 min capture?
    Posted by Lawrence Vaughan on March 16, 2006 at 8:52 am
    I have a problem, I am using premier 6.5 (NOT pro) and I am needing to capture a segment of movie which is over 10 minutes, after about 9 min 30 sec the capturing stops and gives me the option to name the file.
    I have been in the settings and changed the capture limit to infinite but no avail. I have pleanty of hard drive space but I can’t figure this one out, any suggestions?
    Thanks a lot.
    Lawrence Vaughan replied 20 years, 6 months ago 3 Members · 3 Replies
  • Mike Velte
    March 16, 2006 at 12:09 pm
    What capture card are you using? If Canopus, are your setting set for Reference files?
    Is you computer;s file system set to NTFS, not Fat32?
  • Ron Moody
    March 18, 2006 at 5:31 pm
    My guess is that your drive is formatted under the FAT file system rather than under NT. If I remember correctly, the maximum file size using a File Allocation System formatted drive is 2 gig which works out to about 9 minutes or so in the DV format. Using drives formatted under the NT file system removes this limitation (or at least places the file size so high, it’s not a realistic limit anyway).
    Ron Moody
  • Lawrence Vaughan
    March 20, 2006 at 3:24 pm
    yeah, you are right. I am using a DV storm 2. I tried it in a friends machine the other day and it worked fine and his drive is NT.
    Thanks anyway
