Activity › Forums › Media 100 › More rendering mysteries in 12.1.3
  • More rendering mysteries in 12.1.3
    Posted by Kieran Matthew on April 29, 2008 at 1:33 pm
    Hi Folks
    I’m doing a project that (as usual) uses lots of graphics layered up. And (as usual) things aren’t going to plan.
    The project uses the Media 100 lossless codec, but every so often the titles turn italic even though the codec hasn’t changed.
    Rendering everything doesn’t help (though the italics disappear)
    Attempting to “render range to bin” or just plain export results in the system deciding that things need to be rendered even though there’s nothing but green on the timeline. Even if I proceed with the render it renders EVERYTHING again.
    Attempting to make freeze frames results in Solid green, or Black clips. Even if they appear OK in the viewer and bin, placing them in the timeline makes them go black.
    Any ideas what is going on here?
    K
    Kieran Matthew replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
