Activity › Forums › Apple Final Cut Pro Legacy › more RAM in MacBook Pro
  • more RAM in MacBook Pro
    Posted by Todd Reid on May 10, 2007 at 2:36 am
    I currently have 2GB of RAM in my MacBook Pro. The apple store will configure a MBP with a max of 3GB, in one slot a 1GB the other a 2GB.
    I always heard to match pairs (learning in recent post that is a FCP suggest not mac).
    Apple store says max is 3GB, cruical.com says that each SLOT has a max of 2GB.
    Can I/Should I buy 2 (2GB sticks) to take my MBP to 4GB?
    Since I’ve never done it, I would feel weird having unmatched pairs (1GB-2GB).
    Anyone have 4GB in a MBP?
    Todd Reid replied 19 years, 4 months ago 3 Members · 3 Replies
  • Jeff Carpenter
    May 10, 2007 at 3:25 am
    Ok, since I was the one who said matching was a FCP thing, not a Mac thing. Here’s a couple of things:
    1) When talking about the Mac Pro (as we were) it’s important to remember that you absolutely HAVE to have matched pairs of RAM. What I said was that you could have 2 pairs that didn’t match if you’re not a Final Cut Pro user. (So we’re talking about 4 chips.) So having two 512 chips and then adding two 1 GB chips would be ok (as far as the Mac is concerned…Final Cut would prefer that they all be the same). So even though the pairs don’t have to be paired, yes you totally have to have an even number of chips where each pair has matching chips.
    2) That’s only true for the Mac Pro.
    3) HOWEVER, the Macbook (regular non-Pro) and Mac Mini really like matched RAM too. This is because they don’t have video cards. Their system RAM gets shared as video RAM. The system will work with an un-matched pair (or one chip) but you’ll get better video performance with a matched pair. That only applies to those 2 computers, however. All the rest have dedicated video cards with their own video RAM.
    4) The iMac and the Macbook Pro’s motherboard can only read 3 GB of RAM. You can put 4 GB in them (2 x 2GB) but the machine will only read 3 GB. You’d be wasting your money to buy 4 GB.
    5) By getting an un-matched pair in the examples in #4…are you sacrificing performance? I really don’t know. I’d think so, but Apple sells them that way so it can’t be terrible. My best guess is that having 3 GB is worse than having (the impossible) 4 GB, but it’s still better than having 2 GB. So I’d say go for it.
  • Colin Mcquillan
    May 10, 2007 at 5:13 am
    which generation of MBP do you have?? if it’s the first run 2.16ghz 17″MBP I believe you are stuck with a max of 2 gigs. The 2nd run 2.33ghz is capable of 3gigs.
    Colin McQuillan
    Vancouver BC
  • Todd Reid
    May 10, 2007 at 12:44 pm
    I have a first run, so I guess I’m stuck.
    I thought this might be the case, as I’m not sure why I would only get 2GB of Ram if I had ther option for more.
    thanks
