Activity › Forums › Apple Final Cut Pro Legacy › more questions about graphics rendering codecs…
  • more questions about graphics rendering codecs…
    Posted by Alexander Gao on December 16, 2005 at 1:46 am
    Thanks to Todd so much for answering my last post about graphics in fcp. He said i could not get the resolution I was aiming for without making costly upgrades, as I was working in mostly dv project. I have a question though: although graphics look horrible rendered as dv (because i only have the computer and no extra tools i guess), is it possible to render the whole timeline as animation, including the video? What will happen to the video if rendered as animation? Thanks for feedback.
    Todd Beabout replied 20 years, 9 months ago 3 Members · 2 Replies
  • Shane Ross
    December 16, 2005 at 2:09 am
    What is your goal? What are you outputting to?
    Don’t use Animation…That is mainly a TRANSPORT codec…HUGE filesize. Better to try 8-bit or 10-bit uncompressed. But then, to output to tape you’ll need a capture card, and those codecs cannot be laid to DV tape, only Beta, Digibeta, and the like.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Todd Beabout
    December 16, 2005 at 5:28 pm
    We use Animation codec quite alot to go from AE to Avid or FCP, and it works fine with footage as well. If you want a way to get your final product output to tape without the DV compression this could be the way to go.
    You could export everything, once completed, to a QuickTime with Animation codec and burn that to a data DVD or CD (or even an external FireWire drive if it won’t fit) and bring that to a post house or TV station that would make the dub for you from an uncompressed Avid or FCP box. Unless you know what system they have, Animation would be a good choice for delivery. Another option would be an image sequence. If they do happen to have a FCP box, then Shane’s suggestion of the 10 or 8-bit Apple codec would be ideal.
    Good luck, and post back with your results!
    -Todd Beabout
    Vazda Studios
