Activity › Forums › Adobe After Effects › more newbie questions
  • Walter Soyka
    December 7, 2020 at 6:46 pm
    If you right-click a keyframe (or a group of keyframes), you can select “Toggle hold keyframe.” This holds the property’s value constant until the next keyframe, where it will instantaneously switch instead of smoothly tweening.
  • Carlos Fonsalía
    December 7, 2020 at 7:04 pm
    hi, the video copilot twitch plugin, it has a preset called blinking, it is very good and I use it in my proyects, in any case if I did it manually, it would be the fusion of fast blur + brightness and contrast with the expression “random”
  • Stacey Dunleavy
    December 7, 2020 at 7:58 pm
    BINGO! That saves me from having to figure out the Java for the Scale Bounce preset…
