Activity Forums VEGAS Pro more network rendering problems
  • more network rendering problems
    Posted by Anthony on July 29, 2005 at 11:34 pm
    I did everything like I was told , a few questions?
    Do I keep both of vegas render service boxes open for 53704 and 53705?
    Also when I try to add a second line under render in either box I get failed to add peer something like cant add host computer.
    When I did try to render it was very slow like the cpus are not the same, The times of the two are very different.The cpu is a dual core x2 4200 amd
    Man someone should write a vegas for dummies tutorial on this lol
    Also I heard that mpeg2 encoding on vegas 5 will use dual processors is that true?
    Gary Kleiner replied 21 years, 1 month ago 2 Members · 4 Replies
  • Gary Kleiner
    July 30, 2005 at 12:30 am
    [Anthony] “Man someone should write a vegas for dummies tutorial on this lol”
    Actually, I do a step-by-step demonstration in The Vegas 5 Companion video.
    If you are using Vegas 6, there will be little to be gained by a render distributed within the same machine. Just make sure that your video preferences are set so that you are using 4 threads.
    Gary
  • Anthony
    July 30, 2005 at 12:41 am
    Where can I buy your Vegas 5 companion? Your Vegas 4 dvds started me on the to Vegas 🙂
  • Anthony
    July 30, 2005 at 12:45 am
    Found it ,also Im using vegas 5 downloaded vegas 6 demo and it kept freezing up . So im sticking with 5 for awhile lol
  • Gary Kleiner
    July 30, 2005 at 12:57 am
    [Anthony] “Where can I buy your Vegas 5 companion?”
    The Vegas 5 Companion, DVD Authoring with DVDA 2, The Vegas 6 Primer and the upcoming Vegas 6 Companion and DVD Authoring with DVDA 3 can all be ordered at http://www.VegasTrainingAndTools.com.
    Gary
