Activity Forums VEGAS Pro More Keyframe Kraziness…Cont’d!
  • More Keyframe Kraziness…Cont’d!
    Posted by Matt Schwartz on September 11, 2007 at 3:52 am
    Hi, I’ve mentioned this kind of continuing keyframe issue…..It seems for an EVENT, you can uniformly change brightness or contrast easily by a single initial keyframe setting, ok. But for Track effects like brightness/contrast and many others, it becomes MUCH more involved. Any adjustment is of course a KEYFRAME setting and the subtle issue is not what you are adjusting at THAT POINT, it’s what VEGAS is doing before and after that point as it connects the dots! Whoa! This seems to have serious continuing ramifications. Even if I use track brightness and contrast (to save myself from voluminous event FX settings), it seems always necessary to have a beginning keyframe and identical ending keyframe for a chosen segment – so vegas does NOTHING inbetween other than keeping the fx settings constant! My God, this is double work, do you see what I am getting at? ALL these effects are keyframe driven! Is there anyway around this when using track effects?
    Do YOU run into these issues, what do you recommend?
    Matt Schwartz replied 19 years ago 2 Members · 2 Replies
  • Edward Troxel
    September 11, 2007 at 12:08 pm
    A “Hold” keyframe won’t gradually change values when going to the next keyframe.
    Edward Troxel
    JETDV Scripts
  • Matt Schwartz
    September 12, 2007 at 4:29 pm
    Perfect! Exactly what’s required here. Thanks!
