Activity Forums Apple Final Cut Pro Legacy More HDV ?’s
  • Posted by Paul Boyer on April 15, 2006 at 1:59 pm
    I rented the sony HDV deck (the 10) and get a great picture in the little LCD monitor, andf FCP5.0.4 recognizes it + see timecode, but I get no picture. I’ve done the easy setup and everything seems to be online except picture and sound. Any ideas?
    Happy Easter and Thank You.
    pb
    HD Production/Post
    Varicam
    1200 Firewire & 1080i cards installed
    All DVCAM & Mini DV
    Pansonic 100a
    sony pd150’s
    Arri srII (16mm) Arri III (35mm) vp’s & other lenses. Time lapse mitchells … all in house
    Georged replied 20 years, 5 months ago 2 Members · 2 Replies
  • Paul Boyer
    April 15, 2006 at 2:47 pm
    the deck can be adjusted to downconvert to dvcam, in the menu’s. That has to be turned off. I don’t understand why anyone would downconvert when it saves so little (cheap) space but costs so much time. But, Im a freak!
    pb
  • Georged
    April 18, 2006 at 3:22 pm
    i’ve also had this problem. I switched off auto selection between dv and hdv export on the deck. Setting it to HDV only. then the image came up in the digitising window. regardless of the timecode etc. until you get an image instead of color bars you are not able to capture. also, it’s a bit finickity in terms of whether the deck is on before the computer boots or before fcp starts. i find switching the mac on, then the deck, then starting fcp works best.
