Activity Forums Blackmagic Design More fcp 5.0 w/ bmd 5.0b2 problems /bug report
  • More fcp 5.0 w/ bmd 5.0b2 problems /bug report
    Posted by Mathias on June 8, 2005 at 3:47 pm
    The following problem has occured several times the last few days; (quoting my comments in the crash report form)
    After rendering a blackmagic 10bit PAL sequence, the playback rate altered to approx 10x (both audio and video). I have encountered this problem often recently (since installing fcp 5.0 w new decklink beta-drivers), so i decided to check if the playback rate in quicktime player was the same – which it wasn
    Steve Drew replied 21 years, 2 months ago 3 Members · 2 Replies
  • Kristian Lam
    June 8, 2005 at 7:50 pm
    Can you send us the crash report via our support webform?
    https://blackmagic-design.com/support/contact/
    Regards
    Kristian Lam
    Blackmagic Design
  • Steve Drew
    June 9, 2005 at 9:34 am
    Hi Mathias,
    I had this issue last week suddenly too.
    Only thing is, I’m on OSX.3.8, FCP4.5 & QT6.5.2.
    I’ve not seen the problem before or since and have no idea what may have caused it, aside from my storage drives being dangerously full.
    A restart solved my problem.
