Activity Forums VEGAS Pro More DVDA questions
  • More DVDA questions
    Posted by Paul Gregory on June 15, 2014 at 4:33 am
    In DVDA should I be able to link anything to anything else. For instance can I have use the navigation button to go to another chapter mark say on another menu?
    Can an end action link to any other menu or menu & chapter?
    I notice that the preview warnings have different colors. I have 2 warnings saying audio needs to be re compressed. One warning is yellow the other one blue. What is the difference?
    Thanks in advance
    John Rofrano replied 12 years, 2 months ago 2 Members · 1 Reply
  • John Rofrano
    June 15, 2014 at 7:35 pm
    [Paul Gregory] “In DVDA should I be able to link anything to anything else. For instance can I have use the navigation button to go to another chapter mark say on another menu?”
    You can have a button go to any chapter you’d like. Just add a new button, set it’s media, and set the starting chapter for that media and that’s where it will go.
    [Paul Gregory] “Can an end action link to any other menu or menu & chapter?”
    Yes. An End Action can go to any menu or any video. If you set it to a menu, you can select which button to highlight. If you set it to a video, you can select the chapter to start at.
    [Paul Gregory] “I notice that the preview warnings have different colors. I have 2 warnings saying audio needs to be re compressed. One warning is yellow the other one blue. What is the difference?”
    Don’t know. I’ve only seen blue warnings. If you select one of the warnings and then press the Question Mark in the upper right corner, it will explain the warning in more detail.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
