More DVDA Questions–(4.0)
Hi guys,
I am preparing a 50 min SD DVD movie with 24 chapter menus. There are a lot of Curves and Color Correction. Get this, the Render to MPEG2 16×9 was 11 hours….I mostly do work under 15 min..
1. If I shot the footage in 24P, I also edited in 24P. Do I render to 24P OR the 29.97 DVDA default…. I want it to be 24P
2. Why does DVDA do a secondary render for 2.5 hours? My Bitrate settings are JETDV’s- Again the movie is SD 50 min.
8,000,000
6,000,000
2,000,000
VBR
Since its 50 min, it should fit on ONE disc.Why the Re-render?
Should I consider setting up a Sony Render Farm? Can you point me to where that information is?1. On the DVD I have static Chapter frames, the background is a 30 second MPEG-2
Thomas
