Activity Forums Apple Final Cut Pro Legacy More colour issues with fcp / compressor / h.264
  • More colour issues with fcp / compressor / h.264
    Posted by Martyn Greswolde on September 30, 2010 at 6:05 pm
    hi all, i know there are colour issues with anything quicktime related but im really struggling with this, this is a screen gram of what compressor is telling me i should be getting and below the same frame from the video output
    https://grab.by/6DFX
    how can i fix this?
    Bizarrely the prores file also looks desaturated on playback but is the right saturation in compressor!!!
    Greswolde Photography
    http://www.greswolde.com
    I know little but I learn quickly!
    Martyn Greswolde replied 15 years, 11 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    September 30, 2010 at 6:26 pm
    have you enabled FCS color compatibility in your QT prefs?
  • Martyn Greswolde
    September 30, 2010 at 6:36 pm
    Jeremy, thanks for the reply. I certainly have, although unchecking it didnt seem to change anything!
    I think i have the culprit though, it is just quicktimes rendition of the video thats off, in this screengrab VLC is at the top and QT is at the bottom, a massive difference.
    https://grab.by/6DIU
  • Martyn Greswolde
    September 30, 2010 at 6:42 pm
    OK, after i turned off fcp colour support in QT and nothing happened, when i turned it back on it did correct the issue. Either I have had far too much rum or it wasn’t turned on in the first place (im sure it was as I haven’t even started on the rum yet) or something screwy was happening to QT. either way its all good now.
