Activity › Forums › Apple Final Cut Pro Legacy › More Canon 7D/Final Cut issues…
Posted by John Sinclair on August 1, 2010 at 5:23 pmStill struggling with importing Canon 7D footage. I have the plugin, connecting camera to Mac, and know you have to go to the root folder and bring all your files in — not just the *.mov files. But in Log & Transfer, it doesn’t see my camera. So I bring the footage over on to my Mac, and seems there are only *.mov files. And then I can’t get Log & Transfer to recognize the root folder — no thumbnails come up.
I’m really not this dopey…..what am I doing wrong?
Phil Balsdon replied 15 years, 9 months ago 7 Members · 7 Replies -
Ernie Santella
August 1, 2010 at 5:38 pmMaybe this thread will help
https://forums.creativecow.net/readpost/8/1094728
Ernie Santella
Santella Productions Inc.
http://www.santellaproductions.com -
Michael Sacci
August 1, 2010 at 6:11 pmThis is a straight forward process IF you do it the right way with the right gear.
Have you loaded the Canon Software?
Then you do not hook the camera up to the computer, you get a card reader, you transfer everything in the DCIM Folder (including that folder) into a new folder on the HD, you put every card into a different folder. So you have YOUR FOLDER/DCIM/100CANON/files .mov and .THM.
In L&T you go to the DCIM folder and everything should be there.
It is a good idea to make your folder a descriptive name since this will be used by FCP as the REEL name.
Peter Wiggins
August 1, 2010 at 7:20 pmEven easier is to make a disk image of the card onto your hard drive.
Peter
Phil Balsdon
August 1, 2010 at 9:50 pmI use the make a Disk Image method on location and copy to an external hard drive.
The Canon Plugin works on my MacPro with OS 10.5.8 in FCP7.
It does not work on my MacBook OS 10.5.8 with FCP 6 fully updated.
I’m doing exactly the same thing on both systems, FCP 6 on the MacBook gives me an incorrect file structure message.
Are the other people (there’s been a few posts on various forums) having this problem only on FCP 6?
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
https://www.steadi-onfilms.com.au/ -
Bouke Vahl
August 2, 2010 at 8:37 amIf the plugin does not work, you can use this to get TC on your QT’s.
https://www.videotoolshed.com/product/42/qtchange/2Then transcode any way you like.
(Or, transcode first, keep the name start the same, keep the .THM and add TC afterwards)If you copy on location to harddisk, you might want to use this:
https://www.videotoolshed.com/product/15/offloader/2It transcodes for you, and adds TC, and makes a backup from the originals as well.
Bouke
smart tools for video pros -
Joe Bryan
August 3, 2010 at 5:33 pmI think the problem is using the camera. I had to got a card reader to make it work.
Phil Balsdon
August 7, 2010 at 8:33 amI just got around to upgrading FCP6 to 7 on my MacBook.
The Canon Movie Plugin works fine now. Nothing else changed.
