Activity Forums Apple Final Cut Pro Legacy more AVCHD migranes. not the usual!
  • more AVCHD migranes. not the usual!
    Posted by Will Del mar on September 30, 2009 at 9:44 am
    Hi all,
    Before I get down to the gritty bits, i just want to say that I know to capture my avchd through log and transfer, and I’ve already turned off my perian!
    My problem, that i am having with two different avchd camcorders (one sony, one panasonic) is that the cards only seem to register randomly in fcp! sometimes when I plug them in, it’s carnival time and i get to do the logging and transferring. most times though, i plug the card in, navigate to the drive in the window, select the appropriate folder and…nothing. select other folders. nothing. unplug, replug drive. nothing. restart. nothing. reopen fcp before i plug in the drive, nothing. nothing makes any difference. just now and then, it works.
    I have successfully l’d and t’d avchd on my computers (it happens on both my macbook pro and my imac – both intel core 2 duo) but it’s always this struggle to get started. i run 10.5.8 and fcp 6.0.6 on both machines.
    so frustrating!!!
    any ideas on this one?
    Arnie Schlissel replied 16 years, 12 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    September 30, 2009 at 1:14 pm
    Sounds like a mystery. But have you tried a different card reader?
    Also, try copying the contents of a card to a folder on a hard drive, then use L&T. If that works consistently, it could also point to an issue with the reader.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
