Activity › Forums › Apple Final Cut Pro Legacy › MORE AUDIO SAMPLING/FLIP 4 MAC CONCERNS
  • MORE AUDIO SAMPLING/FLIP 4 MAC CONCERNS
    Posted by Dunwoody Lampton on July 31, 2007 at 7:58 pm
    Also getting the “audio sampling” error when attempting export with Flip4Mac WMV Studio. The workaround on the Flip4Mac site says to select the sequence, select the sequence tab, adjust audio to 44.1, render audio, then export.
    However, my F.C.E. HD 3.5.1 does NOT show an option under the sequence tab for adjusting to 44.1.
    Flip4Mac also suggests a workaround using Quicktime Pro, but I do not own, nor do I plan on purchasing, QT Pro.
    It is my guess that the first workaround utilizes sequence options available in Final Cut Pro, and not Final Cut Express.
    Thanks in advance for help.
    Russell Lasson replied 19 years, 2 months ago 3 Members · 3 Replies
  • Russell Lasson
    July 31, 2007 at 8:56 pm
    I just started getting an error on a project like this. I’ll let you know if I find out what causing it.
    -Russ
  • Tom Wolsky
    July 31, 2007 at 10:38 pm
    You’ll have to wait for Flip4Mac to fix the problem, because I don’t think you have any way to do it with FCE.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Russell Lasson
    August 1, 2007 at 6:50 pm
    I get it now. FCE doesn’t allow you to change the audio to 44.1, right?
    Without QTPro, I can’t think of a workaround for that.
    -Russ
