Activity › Forums › Apple Final Cut Pro Legacy › More Aspect Ratio
More Aspect Ratio
Posted by Lucas Cheadle on March 15, 2009 at 7:45 pm5 minute ProRes project, exporting to FLV through QT conversion. I check the output in MpegStreamclip and the image is squished horizontally. I’ve tried many variations within the Flash encoder to try to maintain the 16×9 ratio to no avail. What should I do?
John Fishbackreplied 17 years, 6 months ago 4 Members · 4 Replies
Arnie Schlissel
March 15, 2009 at 9:44 pmI don’t know how you expect anyone to help you, because you haven’t told anyone what your original material was, and what your target is. It’s kind of like phoning up your mechanic and saying “Fix my car”, then hanging up.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Lucas Cheadle
March 16, 2009 at 12:01 amWow. That’s harsh. I certainly won’t be calling you up to fix my car!
Here’s what I wrote:
“5 minute ProRes project, exporting to FLV through QT conversion”ProRes = HDV
FLV = Flash = webSo there it was… original source & target, right?
Rafael Amador
March 16, 2009 at 2:54 amJust make sure that the output size keeps the 16×9 proportions. So:
– 160×90
– 320×180
– 480×270
– 640×360
…….etc. And all the in between values that keeps the same proportion.
Your clip will look properly Anamorphic in QT, FP or WMV.
Rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
John Fishback
March 16, 2009 at 10:05 pmUse the On2 VP6 codec for highest quality. Un-click maintain aspect ratio before entering the 16:9 size. Otherwise it’ll default to 4:3 if that was the last setup used.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
