Activity Forums Apple Final Cut Pro Legacy More 4 channel audio for broadcast ?
  • More 4 channel audio for broadcast ?
    Posted by Dave Francombe on September 12, 2007 at 2:08 pm
    I am so close to outputting 4 channels to tape, but need a little more help.
    For reference Network requires.
    Full stereo mix including music/Fx on 1/2
    Mono mix of Vo/Nats/Sot on 3
    Mono Music on 4
    So I have set up my 4 channel outputs in the sequence>audio output and this is working.
    1 & 2 are set for stereo
    3 & 4 for mono
    I understand how to assign each timeline track to an output also. My question now is about mixing down in the time line. Right now I am using a1/a2 for vo/sot a3/a4/a5/a6 for stereo music, a7/a8 for FX. Do I need to mix these down to a1/a2 to output ? I have tried to nest “with mixdown” selected all the audio but when I do, it is creating audio on a1 thru a4, I removed a3/a4 and it still sounds fine, but is this right. Once I get this mixed, I then copy and paste my original audio to unused tracks and assign these lower tracks to 3 or 4 as required.
    Is this the best way of doing it ? Cheers
    Travis Ballstadt replied 19 years ago 3 Members · 3 Replies
  • Walter Biscardi
    September 12, 2007 at 2:25 pm
    The best way to do is to export a full stereo mix from your timeline and then lay that onto Tracks 1 / 2 and assign those to outputs 1 and 2.
    Then do an export of all elements for Audio Channel 3 and lay that onto Track 3.
    Then do an export of all elements for Audio 4 and lay that onto Track 4.
    You can’t assign one audio channel in FCP to multiple tracks of output. You have to create two audio mixes for your four tracks of output.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Dave Francombe
    September 12, 2007 at 7:29 pm
    thanks walter. How is the correct way to do the mix export ? Via quicktime conversion, send it out as a wav ?
  • Travis Ballstadt
    September 14, 2007 at 3:26 pm
    I use Soundtrack Pro for this. It’s pretty quick and easy to send your sequence to STP, then create a bus for 1, 2, 3, and 4, I add a little compression to the busses to even up the levels a bit, and then route each bus to it’s own output.
    Then I export Channel Grouped, which will give me 4 separate files for each channel.
    Drop those onto your FCP timeline, route them to the proper output there, and print to tape.
