Activity Forums Apple Final Cut Pro Legacy Mono to Stero???
  • Mono to Stero???
    Posted by Brian Pitt on December 13, 2005 at 9:27 pm
    I have a video clip that only has mono audio. I need to fill that audio into the other channel so that I have stereo audio. I can’t for the life of me figure out how to do this. I’d appreciate any help. Thanks!!
    Brian
    Richard Martz replied 20 years, 9 months ago 4 Members · 4 Replies
  • Bouncing Account needs new email address
    December 13, 2005 at 9:37 pm
    You can PAN the track to CENTER.
    Or you can duplicate it and put it on two (both “left” and “right”) tracks.
  • Brian Pitt
    December 13, 2005 at 9:42 pm
    thanks! I knew it was something like that, but I was racking my brain trying to figure it out. I used the pan method. How do you put it on left and right track using the duplicate method?
    Brian
  • Frank Nolan
    December 13, 2005 at 10:13 pm
    By duplicating the clip and putting it on track 2 (holding down option and dragging it down) you are not making the clip stereo. It is just dual mono. Be careful if you use this method as sometimes the phasing will cause the tracks to cancel each other out and you will get horrible sounding audio. Better to just pan the track to center.
  • Richard Martz
    December 13, 2005 at 10:14 pm
    To duplicate the track you can just select the audio track you need and just copy the track. The next thing you do it to paste that track into the blank audio track.
    However you will still have a mono track so using the PAN function will yeild approximately the same result. If you are using a track that is primarily music or sound effects you can sometimes insert a one, two or three frame delay from the original track and simiulate a stereo track. If you try this you can put the original track on channel Left with a hard pan and the delayed track on Channel Right and you can hard pan that opposite the original track as well. Then listen and experiment with both the delay and the amount of pan given to each track. You can arrive at a happy medium that sounds much like an original stereo track.
    Be careful though – If you do this to voices you can end up sounding like the Cylons from the original Battlestar Galactica series. SO that is not something I recommend. Enjoy.
