Activity › Forums › Adobe Premiere Pro › mono plays as stereo
Posted by Ronny Nuyens on September 26, 2015 at 9:31 amHi, I have a clip recorded with 2 different mics, but channel 1 and channel 2 both play in stereo, so when I delete one channel, I still have stereo instead of mono, I really can’t figure this out… Does Premiere automatically turn a mono signal into stereo when it’s imported? Tnx
Ronny Nuyens replied 11 years ago 2 Members · 4 Replies -
Tim Kolb
September 26, 2015 at 3:43 pmIt depends on how the audio is set to ingest in your preferences.
You can set incoming 2 track audio to be stereo, dual mono…dual stereo…etc.
Now…if it is set to dual mono, then the question is whether you mean that a mono clip set in a stereo sequence is still playing across both L-R in the master levels…which would be a matter of panning the audio in the sequence as it’s likely defaulting to pan-center.
TimK,
Director, Consultant
Video Producer at I-CAR -
Ronny Nuyens
September 26, 2015 at 7:18 pmHey Tim, thank you for your response. So by default, even a mono clip plays on both channels? I find this so difficult to grasp, I looked up some tutorials, but they even make me more confused :-/
Tim Kolb
September 26, 2015 at 9:09 pmWell…if you do indeed have a stereo sequence…
The default for a mono clip would be to pan-center, so it would show up on both sides. However, the clip could be panned left or right by either performing that adjustment on the clip, or by panning that track right or left in the mixer.
If you have the audio settings in your preferences set to bring in 2 track camera footage as dual-mono, then both would default to pan-center as they really aren’t a ‘stereo’ pair anymore…they’re distinct mono tracks…and they both default to pan-center, therefore both tracks are playing on both stereo channels.
Does that help?
TimK,
Ronny Nuyens
September 27, 2015 at 6:55 pmActually, if you look at it that way, it kind of makes sense. Tnx again Tim!
