Activity Forums VEGAS Pro Mono Left Audio on a track not a region
  • Mono Left Audio on a track not a region
    Posted by Brad Leigh on October 19, 2011 at 4:14 am
    Hello
    I am editing footage shot on A HDR FX-1 HDV, mixing with AVCHD footage shot from a different angle. On the HDR I had a Lav on Channel 1, and Boom on channel 2. Using Vegas Pro 10. I would like the audio Track that I use for the HDR to use only the left ( Lav ) panned center.
    I did look this up and I can get this to work if I right click the audio region and select Left channel, but it would be nice to do this on the track so every region added to those tracks uses the proper mic, and not have to modify each region as I build my edit. Any suggestions? Heck it might be nice to have it on two mono faders rather than one stereo,
    Is that possible?
    Brad
    i7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 10
    John Rofrano replied 14 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    October 19, 2011 at 4:08 pm
    [Brad Leigh] “I did look this up and I can get this to work if I right click the audio region and select Left channel, but it would be nice to do this on the track so every region added to those tracks uses the proper mic, and not have to modify each region as I build my edit. Any suggestions? Heck it might be nice to have it on two mono faders rather than one stereo, Is that possible?”
    Try selecting the audio track and then choose Tools | Scripting | Stereo to Mono.
    If you all of your audio to come in this way go to Options | Preferences and check Import stereo as dual mono.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Brad Leigh
    October 19, 2011 at 5:01 pm
    John
    Thank you once again. Also thank you for posting those tutorials!
    Brad
  • John Rofrano
    October 19, 2011 at 5:19 pm
    You’re welcome Brad. Glad I could help.
    ~jr
