Activity › Forums › Apple Final Cut Pro Legacy › Mono audio to stereo or two track output
  • Mono audio to stereo or two track output
    Posted by Fredit on January 28, 2006 at 9:58 pm
    Need some help with audio. I’m new to FCP but not to Avid. Video input on project was from a mini DV with an external mono mic. How do I get a two channel output? Thanks for any advice, Fred
    Jeff White replied 20 years, 7 months ago 3 Members · 6 Replies
  • Tom Wolsky
    January 28, 2006 at 10:57 pm
    Center the pan for the mono track, Control-period.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Fredit
    January 28, 2006 at 11:30 pm
    Thanks Tom for the quick response. Tried that with the pan , control-period and hoped it was that easy. Still, I’m getting output on left channel only. My audio tab says stereo (a1a2). Is the problem in my capture settings? I know in avid any mono audio track can be changed to mid in the audio tool.
    Thanks again, Fred
  • Tom Wolsky
    January 29, 2006 at 1:33 am
    What’s happening in the meters when you center the audio? Are they both moving?
    All the best,
    Tom
  • Fredit
    January 29, 2006 at 1:31 pm
    When I center the audio with pan there’s no change. Left channel and right do move on the meters. Left at a normal level, right bounces just a bit at -60.
    Fred
  • Tom Wolsky
    January 29, 2006 at 2:39 pm
    It sounds like you still have a stereo pair. You need to switch that off and get rid of the useless track. When there is only one mono track then center that.
    All the best,
    Tom
  • Jeff White
    March 3, 2006 at 1:31 am
    I’m sorry to jump in so late in the game, but I’m having a similar problem and was hoping someone could help.
    I’m a beginner and just recorded a segment using a DVX100. I used a wired lavalier in channel 1 and could only hear mono audio. The place I rented from said, don’t worry, it will translate into stereo once in FCE/FCP. I’ve just imported the audio and it’s still mono.
    By using Pan, it appears to give me stereo audio. Is this, in fact, the right way to convert to stereo, or is there something different I should be doing?
    Thank you,
    Jeff
