Activity Forums AJA Video Systems Mono audio mix coming from SDI card in monitor
  • Mono audio mix coming from SDI card in monitor
    Posted by Paul Griffiths on September 8, 2009 at 12:38 pm
    Hello, I wasn’t sure where to post this but here goes…
    I’ve got an odd problem. All new kit…
    FCP 6
    Mac Pro
    AJA Kona LHe with breakout box.
    JVC 15″ CRT with IF-C21SD1G SDI board
    <img= "https://www.bhphotovideo.com/images/images345x345/302405.jpg">
    AJA Kona LHe SDI out feeding to SDI in on IF-C21SD1G board in JVC monitor.
    Embedded audio from SDI board Analogue out Channels 1&2 feeding via sperate RCA outputs to mixer (then on to speakers)
    If I feed a stereo source from FCP – i.e some tone swapping from left and right then the mixer registers a constant mono signal on the input, rather than one swapping from left to right.
    To check the SDI output if I feed it to a deck, the meters show a stereo SDI embedded input swapping from left to right.
    My SDI board seems to be mixing the SDI feed to mono and I’ve no idea why.
    I checked the manual and my DIP switches on the board match Channel 1 feeding to Channel 1 and Channel 2 feeding to Channel 2.
    I’m a little stumped.
    Any ideas? 🙂
    hoping,
    Paul
    Paul Griffiths replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
