Activity Forums Apple Final Cut Pro Mono Audio Channel outputs on CH 3
  • Mono Audio Channel outputs on CH 3
    Posted by Tobias Heilmann-schuricht on August 5, 2015 at 8:16 am
    I have a source clip, with one audio channel set to mono. When looking at the inspector I also see the audio setting for that clip as MONO.
    I see the audio on the FCPX meter (which also only shows mono). But I can not hear the audio as somehow this audio channel is being routed to CH3 on the output. I see this from my external audio meter de-embedding the SDI audio.
    When I switch the audio setting of the clip from MONO to LEFT, for example, the audio maps to CH1 and I can hear it.
    Why would the MONO setting map to CH3?
    I am running the latest versions of every software on the system.
    Thanks for any thoughts.
    Tobias
    In Touch Media GmbH
    Germany
    Tobias Heilmann-schuricht replied 10 years, 12 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    August 5, 2015 at 12:43 pm
    What kind of output hardware are you using and how do you have that configured?
  • Tobias Heilmann-schuricht
    August 30, 2015 at 9:06 am
    I am using BMD Ultra Studio 4K connected through TB2.
    There really isn’t much configuring I can detect in the control panel that would affect this issue.
    I am listening to my stereo sum (Ch1+2) via AES/EBU
    I am seeing the channel mapping on my SmartScope 4K which is looking at the HD-SDI signal
    In Touch Media GmbH
    Germany
  • Jeremy Garchow
    August 30, 2015 at 2:06 pm
    I’d have a look at this: https://support.apple.com/en-us/HT204780
    September 13, 2015 at 8:48 am
    Jeremy, thank you! That solved the problem…
    In Touch Media GmbH
    Germany
