Activity Forums Apple Final Cut Pro Legacy Monitoring with Intensity Pro question
  • Monitoring with Intensity Pro question
    Posted by David Grey on September 18, 2009 at 3:35 am
    Hi, doing a TV project and it has been rejected by the network due to interlacing issues as we are apparently using some dodgy footage from the US.
    We don’t usually need to monitor as everything is shot in 1080i, but with some of our footage now coming from the US in all types of crazy formats, I would like to see it as it would end up on TV.
    Would the Blackmagic Intensity Pro card allow me to do this?
    Ie. the network claimed that some footage had “very poor conversion from NTSC causing bad motion judder / motion jump”, “field-order errors”, and “looks like interlaced original footage (50i) has been incorrectly deinterlaced (25p) using a field-merge technique resulting in unacceptable judder / stutter / double images”
    This is from VNRs and footage downloaded from US productions houses which all looked fine in FCP on our computer monitors. So could I plug in a LCD TV via the Intensity Pro that will allow me to instantly see these issues?
    Many thanks, David
    David Grey replied 17 years ago 3 Members · 5 Replies
  • Kai Cheong
    September 18, 2009 at 2:12 pm
    Hi David, to piggy back on your post (I’m one post below yours, mulling over monitoring options as well): would a SD CRT TV connected via an Intensity Pro card be a possible downconverted preview monitor for checking interlacing?
    Kai
    FCP Editor / Producer with Intuitive Films
    https://kai-fcp-editor.blogspot.com
    Now ‘LIVE’! Check Out The Intuitive Films Blog @ https://intuitive-films.blogspot.com
    At Intuitive Films, We Create: TV Commercials, Documentaries, Corporate Videos and Feature Films
    Visit us @ https://www.intuitivefilms.com
    MacBook Pro 2.4GHz | 4GB RAM | FCP 5.1.4 | Mac OS X 10.5.2
  • Chris Linke
    September 18, 2009 at 7:14 pm
    [David Grey] “We don’t usually need to monitor as everything is shot in 1080i”
    I don’t know how 1080i negates the need for monitoring, but if you’re doing television work, you should always monitor.
    Dave addressed your standards issue, but as for monitoring, the Intensity Pro will allow you to output directly to any HDMI-equipped monitor. I use it in a Windows/Premiere setup, but I understand it works fine on Mac Pros running FCP.
    Chris Linke
    PRC Digital Media
    http://www.prcdigital.com
  • David Grey
    September 20, 2009 at 4:49 pm
    Yes I realize they’re different frame rates, but the footage we were supplied was already in PAL format.
    The question was really whether an Intensity Pro would enable us to recognise the stated problems before we send it to the network and look like idiots! If I had known it was unacceptable I would never have used it, but how was I to know?
  • David Grey
    September 20, 2009 at 4:50 pm
    it was a VNR – not film
  • David Grey
    September 20, 2009 at 4:53 pm
    ah yes I know, but we have a very small budget and are used to just using our own footage. I guess I meant we have never monitored as our entire workflow was 1080i including delivery, so we never ran into issues like this
