Activity › Forums › Adobe Premiere Pro › monitoring the time line
Posted by Zeban Bloch on August 10, 2011 at 8:02 pmhow can i monitor the time line with an external monitor or tv_screen
i am runing the p.p 5.5 under win 7
tnx zebanVince Becquiot replied 15 years, 1 month ago 3 Members · 2 Replies -
Deleted User
August 10, 2011 at 8:47 pmOn the less expensive end you could probably output through your firewire connection to a camera and then from there use the composite output to a monitor. On the more expensive end, investigate Matrox, AJA or Blackmagic Designs.
Lee
SAMDOG Digital Post
Calgary, Alberta
Mac Pro 2.66 12-core 16gb ram • FSI LM1760W Monitor • Matrox MX02 • Caldigit HD One 8tb Raid • Euphonix MC Transport • Final Cut Studio 3 • Premiere Pro CS5• Living my life one frame at a time •
Vince Becquiot
August 10, 2011 at 8:49 pmHi Zeban,
If you have a dual output DVI/VGA card, you can set a display as extended and choose it from Premiere’s playback settings for full screen preview. Otherwise, you’d have to add a second card.
The next step in price would be from Black magic, I would recommend their Decklink studio cards which will give you any output you can think of. That will give you a true output for color correction, pixel to pixel monitoring, noise, and audio sync. You’ll also get a ton of output and capture options.
Finally, if all you need is SD output, you can purchase a D/A firewire box and monitor on an analog display.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area
