Activity Forums Apple Final Cut Pro Legacy Monitoring Scratch Narration
  • Monitoring Scratch Narration
    Posted by Martin Nelson on July 28, 2010 at 7:08 pm
    I prefer capturing scratch narration to a bin rather than to a timeline so I use the Log and Capture tool rather than the Voiceover tool. I’ve got a USB mic I plug straight in to my Mac and off I go. But is there a way, via headphones, to monitor audio while recording? Without a deck running, the Preview button under the Audio portion of the Clip Settings tab in the L&C tool is grayed out.
    Could I monitor if I had a deck hooked up?
    Why ask why,
    Martin
    2 x 2.26 Ghz Quad-Core Intel Xeon
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
    Avid Media Composer 4.0.2.20
    Michael Gissing replied 16 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    July 28, 2010 at 7:21 pm
    Might I make a suggestion?
    Create a new blank Sequence solely for recording your VO’s using the VO Tool.
    After recording, drag all those clips into the bin of your choice.
    You can monitor the audio using headphones by simply selecting that option in the VO tool.
    This is a LOT easier than using the Log and Capture tool and you achieve the same goal, putting all your clips into a bin for use in your project.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
    Blog Twitter Facebook
  • Shane Ross
    July 28, 2010 at 7:25 pm
    What he said.
    Shane
  • Martin Nelson
    July 28, 2010 at 7:34 pm
    Thanks for the workaround, guys
    Martin
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
  • Martin Nelson
    July 28, 2010 at 8:02 pm
    Sorry, I swear, I’m looking in the online manual first.
    How do I monitor though? I’ve got headphones plugged into my Mac’s headphone jack and I’ve got the Headphones Volume control on the VO tool all the way up, but nothing comes through my cans. I hear the countdown beeps through my speakers, then nothing. If I switch the Output setting in my System Settings from Line Out to Headphones I hear the countdown beeps through my headphones and then nothing when it starts recording. Levels read on the mic fine and the audio is recorded when I check it after.
    Martin
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
  • Michael Gissing
    July 28, 2010 at 11:50 pm
    I once recorded narration into FCP using the Log & Capture (uncontrolled device) and i had no problem monitoring. I was using a Decklink card and the audio looped through the card output without any problems. Not sure how you have your monitoring setup.
    There is also the option of using Sound Track pro to record narration, especially if you wanted to record to picture.
  • Martin Nelson
    July 29, 2010 at 12:07 am
    [Michael Gissing] “I once recorded narration into FCP using the Log & Capture (uncontrolled device) and i had no problem monitoring.”
    Yeah, I couldn’t manage to find a way to monitor audio that way either.
    [Michael Gissing] “Not sure how you have your monitoring setup.”
    I typically monitor audio through the Built-in Line Output running to analog speakers. For narration, the app, wisely mutes the speakers to avoid feedback. I would like to monitor the narration through headphones, but perhaps I need more equipment than I have to do so. I’m having a hard time getting a clear answer. The Headphones Volume control in the VO tool would make me think there’s a way to do it.
    [Michael Gissing] “There is also the option of using Sound Track pro to record narration, especially if you wanted to record to picture.”
    I’m really just trying to collect the scratch narration first and then cut it in. I often grab a line quickly and move on so I’d prefer (if possible) to do it without leaving FCP.
    Martin
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
  • Michael Gissing
    July 29, 2010 at 12:22 am
    I think the issue is using the onboard audio rather than an I/O card like Decklink/Matrox/Kona. Perhaps there is something in the system preference setup for the onboard sound so it doesn’t mute when using a mic.
