Activity Forums Blackmagic Design Monitoring on non-retina Mbp
  • Monitoring on non-retina Mbp
    Posted by Hendrik Martz on October 4, 2016 at 10:25 am
    Hello,
    i have the following question:
    I have a 2012 non-retina MBP with one TB-port.
    If I attach a TB Display, it would give me a 2nd display and an additional TB-Port.
    Is it possible to attach a BMD Ultrastudio mini monitor with TB to that port and then monitor my PP and Avid Timelines on a 2n external display? Editing on TB Display and previewing and grading on that 2nd external display?
    Has anybody tried that yet??
    Thanx for an answer in advance..
    Shane Ross replied 9 years, 11 months ago 2 Members · 3 Replies
  • Shane Ross
    October 4, 2016 at 10:32 pm
    [Hendrik Martz] “Is it possible to attach a BMD Ultrastudio mini monitor with TB to that port and then monitor my PP and Avid Timelines on a 2n external display? “
    Yes. TB has loop through, so you can go to a TB display, then out of that to an IO device. or to a hard drive, then monitor, then BMD card. It works.
    [Hendrik Martz] ” Editing on TB Display and previewing and grading on that 2nd external display?”
    Yes. I’ve done that, and still do that. I have the exact computer you have. But my BMD device happens to have two TB ports, so I go to IT first, then the external monitor (older one that’s DVI). But I still get my laptop monitor, external computer monitor for second UI display, and the BMD to production monitor.
    Shane
    Little Frog Post
  • Hendrik Martz
    October 6, 2016 at 6:48 am
    Thanx for the reply.
    What kind of BMD device you have, that has two TB outs??
    Hendrik
  • Shane Ross
    October 6, 2016 at 6:51 am
    The UltraStudio 4K and 4K extreme…the rack mount boxes…have two TB ports. They ALL should have them, to be honest..
    Shane
    Little Frog Post
