Activity › Forums › Adobe Premiere Pro › Monitoring multiple mono tracks.
Posted by Scott Davis on September 12, 2014 at 7:34 pmI have a sequence that has multiple clips that have 3, independent, mono audio tracks. It seems like PP is mixing down my audio to a stereo output. My audio meters show a single stereo track. All of my clips are mono and my sequence is mono. Any thoughts?
Robert D’alexis replied 12 years ago 3 Members · 4 Replies -
Christopher Smith
September 12, 2014 at 8:19 pmIf your sequence is set to Mono then your meters should show only one channel of audio.
I have the reverse issue from time to time, as sometimes I want my Mono sequence (containing Mono & Stereo sources) to export Stereo just once, and of course it won’t. I have to make a new sequence to get a stereo export.
Christopher Smith
CBN International
Scott Davis
September 12, 2014 at 8:23 pm -
Christopher Smith
September 12, 2014 at 8:35 pmWow, I don’t know what to make of that. I just played around with a sequence set to Mono Master, and changed settings on the meters, but couldn’t duplicate your issue.
Has PP been doing this for a while or only since the last reboot? You could try restarting PP, and if that doesn’t work, reboot, and see if the behavior goes away. My meters are stereo for “stereo master” sequences, and mono for “mono master” sequences. At least so far!Sorry I couldn’t help.
Christopher Smith
CBN International
Robert D’alexis
September 13, 2014 at 3:06 pmIf I understand your problem right, I suggest you do the following:
1. Create a new sequence.
2. Click on the Tracks tab.
3. Under Audio choose Multichannel for “Master” and 3 for “Number of channels”.
4. Choose Adaptive for “Track type”.
5. Map the audio. For Audio 1, Output 1 is set to 1, Output 2 & 3 are set to none. For Audio 2, Output 1 is set to 2, Output 2 & 3 are set to none. For Audio 3, Output 1 is set to 3, Output 2 & 3 are set to none.
6. Tick “Open” and click OK.
7. Drag your audio sources into the timeline to see the meters.
8. Click on the monitor channels (they turn blue) to activate all of them.
HTH
