Activity › Forums › Apple Final Cut Pro Legacy › Monitoring in HD in FCP
Posted by Carlo Ferraro on February 21, 2009 at 11:18 pmI got a MacBook Pro 17′ with an Acer 22’as second monitor and Ikan 1080i (with component in) monitor.
Is there a way I can monitor in HD? What do I need?MacBook Pro 17′ 4GB Ram, 512MB Graphics, 2.5GHz Bus 800, E-Sata Lacie Drives
Shane Ross replied 17 years, 7 months ago 4 Members · 5 Replies -
Steve Eisen
February 21, 2009 at 11:46 pmMatrox MXO
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Shane Ross
February 21, 2009 at 11:58 pmOr Matrox MXO 2, or AJA I/O HD. Those are your options with a laptop.
Shane
Read my blog, Little Frog in High Def -
Arnie Schlissel
February 22, 2009 at 1:40 am -
Carlo Ferraro
February 22, 2009 at 5:23 pmShane:
The only at my reach is the MXO.
Since you have a lot of practice with it, I have an aditional question:
I should hook up the MXO DVI-in to the DVI-out of the MacBook Pro, then take the DVI-out of the devive and link it to the Acer 22 LCD and at the same time the Component-out of the MXO to the Ikan monitor.
Does this works this way?
Thanks again -
Shane Ross
February 22, 2009 at 5:51 pmYou CAN do that, but if you do and you go into presentation mode, BOTH monitors will show you the full image. The MXO cannot make an additional desktop AND be an output device. It takes one signal and outputs it via the various outputs. So it would be best to only connect it to the device you want to use to judge your footage when it comes time to color correct. Connecting a monitor via DVI allows you to balance that monitor to BARS. Component outs doesn’t have this option.
CLick on my head at the top and look for my Matrox MXO review.
Shane
