Activity › Forums › VEGAS Pro › monitoring HD by firewire
  • monitoring HD by firewire
    Posted by Enrique Orozco on September 26, 2008 at 4:42 pm
    …working with DV I use to monitor on a std. TV with a Canopus ADVC 300 as OHCI firewire card with excelent results …. I noticed that I can output an HD timeline from Vegas the same way in the same (SD) TV…. am I missing something (besides resolution) ??? is this a “cheap” and good alternative to monitor HD on an external TV ?? If I connect the components output from the canopus, will be an advantage using an LCD bigger HDTV ???
    any comments would be greatly apreciated …
    regards
    Steve Rhoden replied 18 years ago 3 Members · 3 Replies
  • John Rofrano
    September 26, 2008 at 6:06 pm
    You will be disadvantaged working this way. You can’t trust SD output for working in HD unless your final format will olny be SD and never in HD. If you have an HDTV or LCD, then the best option is to connect it to your computer via the second DVI output on your graphics card and use Vegas’ Secondary Monitor preview options. This was specifically added for HD preview.
    You could also use an HD output card like the Aja, or Decklink, but Windows Secondary Display is also acceptable.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Enrique Orozco
    September 26, 2008 at 9:31 pm
    …mmm I have already 2 working monitors and yes, I’ve tried one of them for previewing but I’m not very happy with the result (NOT real time frames/sec) … and as far as I know, there isn’t yet full support from Blackmagic cards with Vegas … AJA I don`t have an idea….
    regards
  • Steve Rhoden
    September 26, 2008 at 9:53 pm
    Well Enrique, you are gonna have to take it up the notch
    when working with HD…there are no shortcuts if you want
    to output the best, visit the AJA website to get a full
    understanding of what their cards do ….
    (solves your realtime problem). But not only is realtime
    an important factor, but also for pre-viewing your output
    on a dedicated HD monitor.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    sample bits at
    http://www.youtube.com/hentys
