Activity › Forums › Apple Final Cut Pro Legacy › monitoring from laptop – P2 workflow
Posted by Ken Zukin on October 27, 2009 at 7:27 pmI have a office-based FCP edit system with a AJA IO-HD, so monitoring with my Flanders Scientific monitor is a no-brainer.
I’m trying to set up a Macbook Pro home environment, and now that I’m using a P2 workflow with no tapedeck, I’m wondering how I can pull a signal out for my system for monitoring. I’m trying to avoid having to transport my IO-HD.
Thanks for the help.
Ken
Jeremy Garchow replied 16 years, 10 months ago 5 Members · 8 Replies -
Shane Ross
October 27, 2009 at 7:30 pmOutput to…what? HDTV? Another Flanders at home?
You will need another IO box…or if you have an HPX-170 or P2 gear, you can use those. The cheapest IO box that works on a laptop is the Matrox MXO2 mini. HDMI out to an HDTV and BAM, there you go.
Shane
Read my blog, Little Frog in High Def -
Walter Biscardi
October 27, 2009 at 7:34 pmYou can drive a Flanders via a DVI adapter from your laptop. Give the folks at FSI a call and they’ll tell you exactly how to set this up.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
John Fishback
October 27, 2009 at 7:42 pmAnother option is the Matrox MXO. Of course when you add the cost of the MXO & a LCD monitor, the price is probably close to the cost of a 17″ FSI.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Ken Zukin
October 27, 2009 at 7:53 pmI have a full-sized Panasonic HPX-2000 P2 camera, so that’s not really going to fit into the post production workflow. I’m really in a tapeless world at this point. I do have an old Sony PVM 20″ monitor kicking around, so I would need some way of pulling a component signal out of the system.
Would the little Matrox box be a good solution??
Thanks again.
Shane Ross
October 27, 2009 at 8:03 pmThe Little MXO2 mini does Component, composite and HDMI.
Shane
Ken Zukin
October 27, 2009 at 8:11 pmThanks, Shane….
One last dumb question — I’m using a 17″ MBP 2.5 GHz that’s about 3 years old. How would I connect up to the MX02 — firewire?? Looking at the Matrox website, it appears that I would need an HDMI output spigot, which I don’t believe my MBP has.
Gracias.
Shane Ross
October 27, 2009 at 8:15 pm[Ken Zukin] “How would I connect up to the MX02 — firewire??”
No. Express34 slot. Firewire is how the AJA IOHD does it.
Shane
Jeremy Garchow
October 27, 2009 at 8:20 pmThere’s also the AJA ioExpress that does HDSDI, analog component, or HDMI in either HD or SD and hooks to computer through Express34.
If you need that port for storage, I’d go the ioHD route.
Jeremy
