Activity Forums Adobe After Effects monitoring clamped output
  • monitoring clamped output
    Posted by Anthony Dupsta on August 30, 2010 at 11:01 pm
    This might be crude, I have been double checking that all my 32bit renders are not clamping by using the info panel. Just making sure I am not clamped at 1 in the highlights. Works just fine, I seek out my brightest white and just make sure it is holding info past 1. This method is fine to use, but is there a more efficient way to do this clamp check.
    Obviously these are EXRs and dpx files I am reading and writing.
    Anthony Dupsta replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
