Activity Forums Audio Monitoring audio on Sony f900r
  • Monitoring audio on Sony f900r
    Posted by Ed Denton on January 18, 2011 at 11:56 pm
    Hi all,
    I recently came across a monitoring problem in the Sony CineAlta f900r and I was wondering whether it was me missing a simple switch or whether it is a flaw in the camera.
    I was sending a split left and right channel to the cameras rear inputs. When monitoring of my mixer I had channel one coming to my left ear and channel 2 coming to my right. But when I listened to the return from the camera I could only get a mix of both channels through both ears. On the camera monitoring section the only choices were 1/3, mix, 2/4 and 3/4. When I looked at the level meter on the side of the camera I could see that it was recording the channels separately. I just couldn’t monitor separately. Is there no way to split monitor channels 1 and 2 on this camera? It seems like a pretty big design flaw audio wise if so?
    Ty Ford replied 15 years, 7 months ago 4 Members · 5 Replies
  • Eric Toline
    January 19, 2011 at 4:26 am
    If you were sending one mic to both channels it doesn’t matter. OTOH if you were sending a boom & a lav to seperate tracks and want hear them individually then you have a monitoring problem. I’m not sure but there might be a 5 pin audio out XLR-M connection on the camera that you could wire up an adapter box to select what you want to hear. Other than that WYSISWYG.
    Eric
  • Ed Denton
    January 19, 2011 at 2:57 pm
    Obviously if I’m only using one mic then it doesn’t matter. Throughout the shoot I was using different combinations of mics, sometimes 2 radio mics, sometimes a boom and a radio mic, sometimes 2 boom mics. But at all times I had one routed to camera channel 1 and the other to camera channel 2. It seems very strange that monitoring on the camera doesn’t include a 1/2 split only a 1+2 mix.
    Sound Devices 552
    Lectrosonics UM400a/UCR411a
    Sanken COS-11 D
    Rode NTG-3
    Oktava MK-012
  • Eric Toline
    January 19, 2011 at 3:28 pm
    Be thankful you can monitor anything. Today it’s almost all wireless hops to the camera where you have no monitor return.
    Eric
  • John Hatcher
    January 19, 2011 at 3:31 pm
    I think it might be an issue in the menu of that camera. I’ve had weird issues with Sony XDCAM cameras like that where it would mix my return and not put channel 1 on left and channel 2 on my right side for some reason. We tried and tried to figure it out.
    You shouldn’t need another blasted external box to do this. Try looking in that menu next time you work with one. There are some hidden menus too sometimes you have to dig down into. Lemme know if you figure it out and I’ll do the same thing next time! 🙂
    Good luck!
  • Ty Ford
    January 21, 2011 at 4:02 pm
    Hello Ed and welcome to the Cow Audio Forum,
    Sony, among others, have for some time allowed left on, right only, mono only mixes from their professional camera headphone outputs. If there’s a 5-pin XLR marked AUDIO on the camera, your lost split will be found there.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field GuideWatch Ty play guitar
