Activity Forums Apple Final Cut Pro Legacy Monitoring audio Drops out
  • Monitoring audio Drops out
    Posted by Tim on September 6, 2005 at 9:17 pm
    HI folks,
    We have installed a couple of new FCP systems with the DeckLink HD Pro 4:2:2 I/O cards. We have been experiencing an audio problem that we have not figured out yet.
    The Problem that we are having is the monitoring audio (S/PDIF) drops out and quits. To get it back we have to reboot the machine. We are running the DeckLink FCP 5.0 drivers. We are converting the S/PDIF output with the Flying cow converter. I know that the converter works fine because we have changed it out (the audio input indicator just goes away on the converter). I have two systems set up identically and they both have the same problem.
    I was wondering if anyone else has had a problem like this.
    (Note: the audio is ok in the embedded HD/SDI path.)
    Tim
    Tim replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
