Activity › Forums › Blackmagic Design › Monitoring 5.1 with BM?
Posted by Sebastian Leda on August 25, 2005 at 9:17 amIs it possible to monitor 5.1 audio with BM?
Sebastian Leda
Editor
Digital Post ServicesSean Oneil replied 21 years ago 3 Members · 3 Replies -
Barend Onneweer
August 26, 2005 at 12:29 pmWell, depending on the setup you have it should be possible. The Multibridge Extreme has 8 digital AES EBU outputs. For 5.1 you need 5 or 6. So it should be possible if your NLE supports the routing.
Bar3nd
Forum COWmunity leader for:
ADOBE AFTER EFFECTS
MAGIC BULLET SUITE
INDIE FILM & DOCUMENTARY -
Sebastian Leda
August 26, 2005 at 6:48 pmWhat would be the set up?
AES DB-25 out of the Multibridge to a 6 to 8 channel D/A to a Martin Sound Multimax to the Speakers?
Sebastian Leda
Editor
Digital Post Services -
Sean Oneil
August 27, 2005 at 8:54 amThe important thing is that with the Multibridge, you have up to 12 digital audio outputs. So where you go from there is up to you. There are countless ways to do it. If you want the dirt cheap example, here ya go… buy a DB25 to XLR breakout cable. Get an AES to SPDIF adapter (XLR to RCA). Buy three consumer stereo amplifiers w/ SPDIF inputs. Send two channels to each one. Plug two speakers into each one. Voila.
Sean
